Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: battery charging
Old 11-22-2009, 02:38 PM   #1
Question battery charging
I have an Intellect 6 cell, 1400 mAh, NimH battery. The charger is a Super Brain 960. The instructions may as well be Greek. Still trying to figure out the proper setting for the battery. Can someone help please? I don't want to kill the battery or burn something up. Thanx.
o3_xterra is offline   Reply With Quote
Old 11-22-2009, 03:40 PM   #2
charge at 1.4amps, 6 cell nimh..? 1400mah
traxxas4fun is offline   Reply With Quote
Old 11-22-2009, 03:40 PM   #3
I have the same charger.
plug in the charger
press the disply button until it says amp
set the amp for 1.3amp
every thing else will set itself
ABOW is offline   Reply With Quote
Old 11-22-2009, 03:42 PM   #4
I think its the batt off the Mini LST.... i ran one...it sits on the axle perfict.
Old 11-23-2009, 12:51 AM   #5
Can you set the peak sensitivity on that charger? If so, I would double check that, sometimes I like to kick it down and shove a few extra MAH's into it.
DaDelta is offline   Reply With Quote
