12-22-2005, 07:55 PM | #1 |
Pebble Pounder Join Date: May 2005 Location: Nor Cal
| 12t pinion
is this pinion ok because i bought one before and the grub screw wouldn't tighten down to the shaft on the motor. can i use this one? and what does the pitch mean? http://www2.towerhobbies.com/cgi-bin...?&I=LXEW97&P=7 |
12-22-2005, 09:10 PM | #2 |
does anyone know because im trying to order it tonight. thanks
12-22-2005, 09:14 PM | #3 |
Quarry Creeper Join Date: Aug 2005 Location: On the yellow dummy dumper
the pitch is the spacing of the teeth. a 48 pitch pinion will only work with a 48 pitch spur gear, a 32 pitch pinion will only work with a 32 pitch spur...
12-22-2005, 09:20 PM | #4 |
Newbie Join Date: Jul 2005 Location: Australia
I use a 12T pinion on my TXT and it works great, make sure you get the pitch right for your truck when you order it, TXT-1 is 32 pitch. (thats if you have a TXT)?
12-22-2005, 10:39 PM | #5 |
will any of these work with my tlt http://www2.towerhobbies.com/cgi-bin...?&I=LXEX47&P=M http://www2.towerhobbies.com/cgi-bin...?&I=LXEX10&P=M |
12-23-2005, 12:33 AM | #6 |
Newbie Join Date: Nov 2005 Location: LI
| 48 pitch
no they wont the previous post said that a tlt was 32 pitch. u need to get the other ones.
12-23-2005, 09:43 AM | #7 |
if you are running the stock tlt spur gear then you need to look for a metric 48 pitch gear. what you can do is get a new spur and a new pinion with a more common pitch like 48 or 32, but its up to you on that one scott |
12-23-2005, 10:35 AM | #8 |
RCC Addict Join Date: Dec 2004 Location: Central NY
heres a good combo for you http://www2.towerhobbies.com/cgi-bin...&I=LXTG41&P=ML http://www2.towerhobbies.com/cgi-bin...?&I=LXN204&P=7 |
12-23-2005, 06:08 PM | #9 |
thanks everyone
12-23-2005, 06:25 PM | #10 |
No problem johnnyt. thats what this section is for, help.
12-26-2005, 12:14 AM | #11 |
does the hpi spur fit on the pede tranny?
