12-21-2009, 06:05 AM | #1 |
Newbie Join Date: Sep 2009 Location: germany
| dual servo steering help
i have a wheely king with dual steering i have my set up is rooster with integy 55t and hitec 645mg servos a castle creations 10amp bec i need help on how to reverse the rear one
12-21-2009, 08:21 AM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
Are you running them off one channel or are you running them on seperate channels? If your running off one you have 2 options you can rewire the servo or buy a "reversing" y harness (recommended) like this one:http://www.rcdude.com/servlet/the-12...Reverse/Detail If you want to go the rewire route:There are four wires that must be switched in order to change the servo direction. Two are on the motor and 2 are on the potentiometer. Switch the red and green wires on the pot and the orange and brown wires on the motor.(at your own risk) Last edited by Mr Glassman; 12-21-2009 at 08:35 AM. |
12-21-2009, 08:23 AM | #3 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
If you only have a 2ch RX/TX you can run it with a servo reverser.
12-21-2009, 08:36 AM | #4 |
12-22-2009, 05:22 PM | #5 |
Rock Stacker Join Date: Dec 2009 Location: maine
Just did this myself, ordered a servo, etc for 4ws for my losi micro crawler, and thought I could make the swap in the harness, but was wrong. I went the rewire route, take your time and it is worth it. Spend the $10+ on a soldering iron, it WILL come in handy.
12-23-2009, 12:03 AM | #6 | |
12-23-2009, 08:17 AM | #7 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Cant you pull the + and - wire out of the servo plug and reverse them and put them back in the plug? Is'nt that what a reverse Y harnes does?
12-23-2009, 08:50 AM | #8 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Moving the wires like that on the plug is BAD... BAD BAD BAD... If you need to physically reverse a servo, soldering is the way to do it if you don't want to get a servo reverser... Or... Flip the servo horn 180* and add some linkage length... That'll reverse the servo on the spot... No rewiring, no cable or adapter.. You may also have to raise the mount point on the knuckle, too, the way it was done in the TLT's back when... |
