01-03-2010, 09:00 AM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Kilgore
| First Rig
Well after going to my first comp I have scrapped the AX10 idea and gone towards MOA. Is this a good starting point? http://www.rc4wdstore.com/2/product_...roducts_id=757 I have a TX and RX from a basher and figure I will change tires for starting. Just wish it had lightweight axle housing. |
01-03-2010, 09:03 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
you need to reread the ad,,it does come with the machined axles
01-03-2010, 09:04 AM | #3 |
Newbie Join Date: Oct 2009 Location: Syracuse
yeah that's a good truck and i wouldn't worry about the axles because the weight is low to the ground you just wont need to weight your tires as much as others running plastic axles
01-03-2010, 09:05 AM | #4 |
Quarry Creeper Join Date: Nov 2008 Location: Orange
the bully is a great rig to start with for moa. if you have and ax10 you can use the same wheels b/c they are the same offset.... try the tires first, you would be suprised what they will do.. |
01-03-2010, 12:28 PM | #5 |
