01-03-2010, 09:03 AM | #1 |
Newbie Join Date: Dec 2009 Location: Dalton,GA
| 16T to 14T ??
Will this offer any difference that I will be able to notice?
01-03-2010, 09:11 AM | #2 |
Newbie Join Date: Oct 2009 Location: Syracuse
most likely the 16 tooth faster than the 14 tooth but the 14 tooth will have more toque you may not notice immediately but the difference will be there and in my experience doesnt matter what one you choose you will be in a situation and wish you had the advantage of the other one
01-03-2010, 09:17 AM | #3 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
01-03-2010, 10:02 AM | #4 |
ax10 .... I just want better crawling performance.
01-03-2010, 10:15 AM | #5 |
Pebble Pounder Join Date: Dec 2009 Location: Who Dat Louisiana
It all depends on what your axial is doing. If you don't have the wheel speed that you need to make it thru some area, then bump up a tooth or 2. But if you have the wheel speed but your rig gets stuck and is lacking torque, you don't need to bump up your pinion. Just post what it's doing and what you want, and I'm sure someone can help you. |
01-03-2010, 10:23 AM | #6 |
sometimes when climbing something my wheels will bind as if it doesnt have the power to turn them so I end up having to back up a little and hit the obstacle with speed to bounce my front wheels over, Id much rather climb than have to jump over things but apparently my current set up doesnt have the power I think it should have lol I just thought a 14T would help with this..
01-03-2010, 12:11 PM | #7 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
It could possibly help, if that's part of the problem. Rig specs? |
01-03-2010, 12:27 PM | #8 |
01-03-2010, 01:23 PM | #9 |
| Sounds like you need more power IE.. torque!!! 55t motor or a lower pinion.
01-03-2010, 01:41 PM | #10 | |
plus the Tazer has brake delay which you dont want when crawling,,and you will want drag brake | |
