01-18-2010, 02:02 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: santa fe
| pinion gear screw stuck
so i am tryin to replace mt 21t pinion gear w/ a 10t pinion gear, and the hex screw that holds the pinion gear in place is stuck, stripped two alan whenchs. can i drill it out, hell i honestly dont know what to do. any help with this would be great. thanks phil |
01-18-2010, 02:04 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
grind the grub screw with a dremel or file and once you get close to all the way it will pop right off.....your replacing it anyways so thats what I would do to get it off.
01-18-2010, 02:08 PM | #3 |
i'm very limited to tools here at work, that is what i figured what to just cut it out but all i got here is a drill i dont own a dremal just yet i will after to day haha thanks |
01-18-2010, 03:04 PM | #4 |
Pebble Pounder Join Date: Dec 2009 Location: Bettendorf
| Dremel
Buying a Dremel was one of the smartest moves I have made in a while... that's not saying much.... :? Anyways go get one... indispensable in my opinion. I didn't think I would use mine much... find myself grabbing it all the time for all kinds of random crap.
01-18-2010, 03:06 PM | #5 |
where would one find an affordable one that wont kill the pocket to much?
01-18-2010, 04:49 PM | #6 | |
| Dremel Quote:
http://www.amazon.com/Dremel-200-1-2...2&sr=1-2-fkmr0 It's a basic two speed corded model that comes with some accessories. I prefer not messing with batteries on a tool that I don't necessarily need to be that mobile with, and the basic two speed model has always been good enough for me. Mike | |
01-18-2010, 04:59 PM | #7 |
walmart is probably the cheapest.
01-18-2010, 05:05 PM | #8 |
| mart |
01-18-2010, 05:21 PM | #9 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
I fth escrew's hole is strupped out (sounds like it may)Here's what I did. It's easy.stripped set screw fix Also there's a standard hex bit, 3/64 IIRC, that'll fit nice and snug. hold a soldering iron to the bit till it starts to get hot. Should expand enough for purchase. Won't damage the yoke either If it's just seized on, You may try heating the screw up with a soldering iron, tightn it a bit and back it out. Sometimes the threads are seized, and need to be "broken" loose. Penetrating oil or oil of wintergreen, will creep in and loosen it up sometimes but you gotta let it work for a few hours most of the time. could you have crossthreaded the grub when you put it in previously? Unless you did that, used red loctite or it's rustedfrom exposure, it should come loose with minimal effort normally. Last edited by solomon7; 01-18-2010 at 05:27 PM. |
01-18-2010, 06:53 PM | #10 |
Quarry Creeper Join Date: Nov 2009 Location: East Bay
I have always had luck with left handed drill bits |
01-18-2010, 07:18 PM | #11 |
lots of guys use loktight on those grub screws. definatly heat it up I usually just use a lighter. but before you do that. if you are using a monkey wrench=l wrench dont. go buy a set of hex wrenches. and dont get the ones with the rounded tips. once you got a full tiped wrench heat up the area the screw is. then lightly tap the wrench into the screw for alittle more bite. I bet that does it. |
01-19-2010, 08:12 PM | #12 |
Pebble Pounder Join Date: Jan 2010 Location: Cincinnati
| Been here done this!
The set screw is 1.6mm hex, and any replacement hex wrench / Allen wrench will twist due to the torsion effect. My solution was to find a screwdriver bit that was the right size. The shaft on it is short enough to withstand the torque, and Dewalt makes a bit set for about $6 USD (I know there are some jolly good fellows from across the pond that post here) The item number is DW2068 9 Pc Hex Drive Tip Set. I put the bit in my screwdriver, NOT POWER DRILL OR SCREW GUN, and it broke the thread locker loose and did not damage anything.
01-20-2010, 04:41 AM | #13 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
01-20-2010, 05:54 AM | #14 |
01-20-2010, 06:00 AM | #15 |
Traxxas TQ2 with 27mhz receiver that makes my Creeper twitch like a crackhead... looking forward to hitting it with a hammer and p***ing on it. ............ i cant say nothing , mine does the same shit lol. |
01-20-2010, 07:19 AM | #16 |
