01-20-2010, 12:23 AM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Bushnell FL
| tamiya highlift lock outs
i did some searching on here and didnt find anything so i figured it was time to ask do they make lock outs for the high lift and where can i get them ? thanks |
01-20-2010, 09:25 AM | #2 |
Wont the TLT rear lockouts work on the Hilift as well?
01-20-2010, 01:37 PM | #3 |
Idk if they will work and is there any mods that you have to do to make them fit? and would it make my axles wider? Thanks |
01-20-2010, 01:44 PM | #4 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
they will fit and wont change the width, but you will need to cut the knuckels off the plastic high-lift housings and trim some more plastic off in order to make these fit. Just like fitting them on TLT axles.
01-20-2010, 01:59 PM | #5 |
Thanks and I'm taking it that they don't make them for the highlift?
01-20-2010, 02:36 PM | #6 |
Yea just use the TLT parts: |
05-20-2010, 03:00 AM | #7 |
Newbie Join Date: Mar 2009 Location: Honolulu
| i had to mod my rc4wd tlt lockouts for my high lift
i know this is old but my title put it as is. of course i had to grind down some plastic parts off my high lift axles to make the RC4WD BUT!!! i ended up having to grind down my dog bones and loose the rubber o-ring that goes into the knuckle to make it fit. i was kinda disappointed by having to do this and it also narrowed my axles quite a bit when i compared to front (completely stock high lift axles) and the rear (RC4WD TLT straight axles lock out adapters) now this is what i collected from the rc4wd axle lockouts, but rcp has one too, so im not sure if these are any better i know they're a little more expensive for the moment because the rc4wd one is on sale? anyone happen to know which is better while keeping the same axle length? |
05-20-2010, 04:21 AM | #8 | |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
05-20-2010, 04:41 AM | #9 |
Pebble Pounder Join Date: Jul 2007 Location: Deland, Fl.
Junfac makes them.
05-20-2010, 02:29 PM | #10 |
RC4WD makes a specific straight axle for the HiLift axles, they are a tad bit wider than the TLT straight axles. This is how I modded my HiLifts.
05-28-2010, 01:46 PM | #11 | |
i had to mod mine to make it fit. | |
05-28-2010, 01:50 PM | #12 | |
is this right? | |
05-28-2010, 02:04 PM | #13 | |
*edit* the truck in my avatar was the one with the lock outs. track width was also fine. | |
