01-08-2006, 07:12 PM | #1 |
1* Join Date: Dec 2005 Location: Ozarks
| Beadlock Question
I didn't know if should go in the Maxx or Tire section, so I'll stick it here. I'm building up a Maxx based Mantis chassis crawler. I plan on using a set of the Maxximizer Beadlock wheels, with Maxx size Moabs or K Rocks. I know from reading the posts it's best to narrow regular wheels for crawling. My question is, do you also have to narrow the beadlock wheels? If so, how much should you cut off? Thanks for any help.
01-08-2006, 09:29 PM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Livermore
i am getting a set of the Pro-Line 40 Series Commando Bead-Loc 23mm HD Hex Wheels and i plain on narrowing them 1 inch from the middle and using plastic epoxy to glue the two haves back together. and i will be running the 40 series moabs with no foams and 9oz of bb's in the frount two tires. hope this helps.
