02-05-2010, 04:48 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Near the ROX BOX
| White Rovers....Direction
Which direction do I want to mount these? Also any tricks before I mounted them? Thanks |
02-05-2010, 06:18 PM | #2 |
Either way you just gotta swap sides to flip em, most guys say with the "arrows" on the center tread pointing forward. I ran mine that way first, then flipped em when the front tread blocks rounded off and the backs were square, then siped and flipped again when the fronts rounded off again.
02-05-2010, 09:32 PM | #3 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
Some will say the direction matters, Personally on the rovers, it does not really matter that much, just make sure all the tires are pointing the same direction. Like IndianaMudcat said, there is a little point on the center tread on the rovers, use that as a guide. Good luck! |
02-10-2010, 12:33 PM | #4 |
Nova foams or is there something better for these tires?
02-10-2010, 04:15 PM | #5 |
RCC Addict Join Date: Sep 2007 Location: Hallsville, Tx
i run mine backwards with nova foams. these tires work really well either direction.
02-10-2010, 04:44 PM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: At your moms,she says hi!
NOvas foams are the best for these tires.
02-10-2010, 09:57 PM | #7 |
Newbie Join Date: Dec 2009 Location: roy
Oversized 2-Stage Rock Crawling Memory Foam from proline seem to work good too.
02-10-2010, 10:04 PM | #8 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
arrows forward are the "A" side and the arrows backward are the "B" side,,I run mine "B" side and I use my custom Paradox foams
02-12-2010, 02:52 AM | #9 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
i run one facing one way and the other facing the other way on the front. And do the same for the rears. |
02-12-2010, 05:36 AM | #10 |
