02-14-2010, 04:22 PM | #1 |
Newbie Join Date: Feb 2010 Location: preston co.
| venom crawler? good starter rig?
i am thinking of buying a venom crawler to start out with does is it as good as an axial ax10? what are good electronics? how good is it at crawling?
02-14-2010, 04:34 PM | #2 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
first time ive seen one in person was last night. it was bone stock from what i could tell Eric -16 -5 -23 = -44 20 pts. (LOSI) Pete -5 -5 12 = 2 19 pts. (LOSI) Bob 4 -13 12 = 3 18 pts. (LOSI) Gabe 19 -17 25 = 27 17 pts. (GO CREEPER!!) Todd 26 -5 19 = 40 16 pts. (AXIAL) Tom 22 19 12 = 53 15 pts. (AXIAL) Bart 25 1 34 = 61 14 pts. (BERG) Cory 50 0 19 = 69 13 pts. (LOSI) Dennie 37 0 34 = 71 12 pts. (LOSI) Nathan 37 30 33 = 100 11 pts. (LOSI) |
02-14-2010, 06:29 PM | #3 |
not bad i do like the axial scorpion because i know somebody that has one but i like the fact that the venom is more alloy than plastic
02-14-2010, 06:36 PM | #4 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
I think its a great starter rig, mostly because its a kit. Building your own crawler get your really fimilair with it and you wont be afraid to take it apart and fix it if osmething goes wrong. Check out ultimatehobbies.com, i think they have them for like $99 or something. Also look at the Creeper forum, you can find a lot of info there! |
02-15-2010, 03:13 PM | #5 |
Newbie Join Date: Jan 2010 Location: Sacramento
I'm building my creeper now. I really like to build the kits. I got mine at RPP for $105. I have some upgrades coming, but I'm going to drive stock for a bit. I don't have an Axial, but I'm going to by the SCX10 to build a scaler. Whatever you choose, have fun!
02-16-2010, 06:10 PM | #6 |
That is where i am planning to order mine at. How are the stock ridgeline tires?
02-16-2010, 06:16 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
02-16-2010, 06:24 PM | #8 |
Newbie Join Date: Feb 2010 Location: Tullahoma Tn
well i traded for a ax-10 scorpion. what should i do to improve it. it has aluminum links and bottom skid. it does have the rtr eletronics. the guy also had the spring removed. should i reinstall them?
02-16-2010, 06:42 PM | #9 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
i would go with the axial (ARTR or KIT) for starter rig with probly an Tekin esc & motor
02-16-2010, 09:35 PM | #10 |
Pebble Pounder Join Date: Dec 2008 Location: Hudson County
I think Venom is a good starter rig because is cheapest crawler kit out there. I started with Wheely King and Venom wasn't even out yet while ax10 was a little pricey for me in case I don't like this hobby. Now that I caught the bug, I'm saving to buy different rigs to play with. There are other options out there depending on your price range.
02-17-2010, 01:30 PM | #11 |
What about flat irons, or leopards?
02-18-2010, 02:18 AM | #12 |
Pebble Pounder Join Date: Sep 2008 Location: New Zealand
| For tires there are almost endless possibilities. Firstly the Flat iron is a scale tire and the Leopard is a flat out top end comp tire, apples and oranges. The stock tires are pretty mediocre. With a serious foam cut and a real good session with a dremmel to delug and sipe they become a bit better. Still a bit sad really. The Lizzard off the AX-10 is a bettter box tire but still needs gobs of work to mke it even o.k. I know as I have a set of them too. Once you have built and run your crawler a few times and begun to tune it to crawl better then you can look at the tires and your terrain and make a very good decision based on the info that is in the Tires & wheels section. The Venom out of the box is fun, a few small adjustments and it gets real fun. A few low cost mods and it is a real hoot on the rocks. Check my build log in the Venom section to see what can be done for a few dollars more. |
02-18-2010, 07:54 AM | #13 |
Newbie Join Date: Jan 2010 Location: Lebanon
I have a creeper and a Losi Night crawler. I have broken sevral part on the creeper and none on the Losi. Also the creeper takes alot more work to make it crawl as good as the Losi. I still like the creeper but if you are going to comp or hard bash you will have to get some upgrades.
02-18-2010, 07:05 PM | #14 | |
Newbie Join Date: Feb 2010 Location: Hastings
Do you have a link to your build log I'm looking into this crawler because my funds are a bit limited. It looks good I'm new to crawlers but not to R/C Trucks/ and Cars | |
Tags |
venom |
