02-23-2010, 11:56 AM | #1 |
Newbie Join Date: Feb 2010 Location: oak harbor
| loud noise on my ax10
hi i just got an ax10 scorpian and there is a loud noise sounds like the transmission.
02-23-2010, 02:10 PM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: Cookeville
describe the noise better. does it only do it when going forward? could be the gear mesh of the motor not line up right.
02-23-2010, 02:12 PM | #3 |
Rock Crawler Join Date: Dec 2009 Location: Lynnwood
pinnoin could be too tight or the spur could be toasted if its a loud screeching noise check those two things first look at the spur to see if there are rocks stuck in it or a tooth is missing or spun |
02-23-2010, 02:58 PM | #4 |
If it's a click the setscrew in the pinion could be hitting the spur, I done that right out of the box.
02-24-2010, 12:41 AM | #5 |
Newbie Join Date: Feb 2010 Location: Prairieville
take it apart and replace the broken parts......... an old man gave me that tip once.. works well |
02-24-2010, 12:08 PM | #6 |
thanks for the tips i will try them an dget back to you
02-24-2010, 12:09 PM | #7 |
02-24-2010, 12:10 PM | #8 |
02-24-2010, 12:21 PM | #9 |
just set up a good gear mesh with the pinnion and spur and slide the pinnion back towards the motor so the set screw clears the spur, check your spur too to see if the set screw munch any spur teeth |
02-24-2010, 04:58 PM | #10 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
Try a different pinion. I've noticed mine is quite a bit noisier with a 14t pinion instead of my 18t.
02-24-2010, 05:03 PM | #11 |
Newbie Join Date: Feb 2010 Location: Victoria
02-24-2010, 05:17 PM | #12 |
Rock Crawler Join Date: Jul 2009 Location: boise
