01-15-2006, 12:58 AM | #1 |
Newbie Join Date: Dec 2005 Location: Hartford
| torque shift
How do I cure the torque twist in the chassis when I am crawling with my TLT? When I am climbing hills and I get on the throttle all it wants to do is lift the right front wheel and I can't figure out why that is. Thanks for the help.
01-15-2006, 01:37 AM | #2 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
There are tons of tricks, running a stiffer spring, or stiffer preload in the left rear helps a ton. Having your shocks mounted on the axles instead of the links helps. Having your shocks standing up more rather than laying down helps. Overall geometry of your links has a ton to do with it.
01-15-2006, 10:17 AM | #3 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
take your upper links and mount them closer to the bottom on the chassis.... i have mine on the same poing and it got rid of torque twist entirely OLD CHASSIS!! |
01-15-2006, 12:34 PM | #4 |
THanks for the help I will be trying a few suggesting out soon.
01-15-2006, 03:33 PM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Yorkshire, UK.
I tried that link setup out on my maxx axles and it just wouldnt have it. I found it wouldnt let the axle remain level when the shocks were pressed down and interfered with ground clearance quite alot. Maybe its me who did sumat wrong i dont no :? |
