03-02-2010, 09:50 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Etowah
| New night crawler
Just got my sons new RTR night crawler in, anything special I need to know or do before firing it up? I've heard some rumors about the worm gears sometimes being wrong and should they need greased or anything before running?
03-03-2010, 09:19 PM | #2 |
| Motor
Also, hearing that these stock motors are a little weak, is this true? If so what motor do you suggest keeping in mind that I have purchased a spare Losi comp crawler tranny with the dig that will be going on it later when money permites?
03-03-2010, 10:05 PM | #3 |
Pebble Pounder Join Date: Oct 2009 Location: Rapid City
I took my LNC out of the box and ran it, no problems. I think the wrong worm gears were a problem of older LCC's. As far as the motor goes it is adiquite but leaves some to be desired, most will say a 35t preferably handwound, or if you got the $$$ brushless is hard to beat. Also weight in the in the tires helps with crawling, but it will amplify the motor and servo weaknesses. |
03-04-2010, 12:19 AM | #4 |
| Brushless
I like brushless, if I go that way will the same ESC work or will it need an upgrade? Just trying to keep the cost down if you know what I mean. Thanks
03-04-2010, 06:49 AM | #5 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
If you want to go brushless, your best bet would be a sensored brushless/esc combo.
03-05-2010, 07:12 PM | #6 |
Ya for brushless the cheapest new is aroun 150 for motor and esc. Sometimes used goat 2s systems come up in the classifieds for under a 100. It is amaing though what a little wheel speed can do for you're crawling.
