03-16-2010, 09:41 PM | #1 |
Newbie Join Date: Mar 2010 Location: san diego
| pinion size help
hey i have a lcc with a 21.5 brushless exceleron, and i am running a 21 tooth pinion... after reading alot of post it seems like a 21 tooth pinion is high... should i get a new pinion. will this pinion cause damage to anything? thanks for any help thanks |
03-17-2010, 12:56 PM | #2 |
Rock Stacker Join Date: Mar 2010 Location: pueblo
| I am no expert on rc gearing but I do know a little about gearing in general as I own several mx bikes the 21 tooth pinoin my be too high a gearing for crawling depending on your spur gear Robinson racing makes a pinion gear starter kit that contains six pinions odd or even sizes the pinion you have shouldnt hurt anything as long as your not overtaxing your motor with it, a lower toothed pinion will give you more torque with less overall speed same applies with installing a bigger spur gear just remember more torque = more power applied to gear train just make shure if you buy a new pinion its the same pitch as the original spur otherwise they won't be compatible with each other, resulting in chewed up gears. If your comfortable with the torque and wheel speed your getting now then your ok. if not try a smaller pinion no harm no foul the advantage with the robinson spur gear kit is it allows you to experiment with different gear ratios for a resonable cost (kit cost approx 12 bucks) just dont forget to set your gear mesh so you dont chew stuff up. hope this helped you out |
03-17-2010, 05:36 PM | #3 | |
Rock Stacker Join Date: Feb 2010 Location: Race City(Mooresville)
03-17-2010, 06:13 PM | #4 |
some people are good at setting mesh by feel or u can put paper between the gears to set the mesh. for a 21.5t in a losi a 14-16t is best bet
03-17-2010, 07:10 PM | #5 |
Oh, I'm running axial rtr stock motor with a 12t. My lash is prob close to that?, maybe? I will check it…
