03-17-2010, 01:17 PM | #1 |
Pebble Pounder Join Date: Mar 2010 Location: Morristown TN
| Loosing power ... wont hardly climb???
I was running my Losi Comp Crawler today at lunch on a full charge and after about 15 - 20 minutes of run time on fairly steep climbs it started loosing power to the point to where it wouldnt hardly climb moderate to steep inclines ... as in the wheels wouldnt even turn. It always has plenty of power unless the wheels are in a bind. I checked the motor temp and it was around 180. I let it cool down on my way back to work and wont get to try it again til tomorrow or maybe tonight. Is the motor temp causing this or does it sound like the battery is getting low? I have got close to 40 minutes of run time before with the same battery, thats why i dont think this is the problem. Im new at this so im just trying to figure out the problem so i can get a head start on it after i get off work today .............. thanks!
03-17-2010, 07:02 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
Most likely it's the battery
03-17-2010, 07:18 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
NIMH OR NICD??? Compleatly drain the battery with it in the truck, lift the wheels and gass it untill the battery is compleatly dead. try recharging the pack at a lower amp rate. do this a couple of times and hopefully it will regain some life.
03-17-2010, 07:40 PM | #4 |
Keepin your axles greased too? That always helps, but your motor temps are pretty high for such a short run, for 25mins I get around a 115- 120 degree temps, I'd step down a tooth or 2 on ur pinion, and if its a nicd or ninh battery you have to run them dead then charge them fully otherwise they can get memory and not last as long, but try a diffrent battery and let us know
03-18-2010, 05:34 AM | #5 |
My bad i meant to list what it had: Im running a 2 cell Lipo with a 55 turn brushed motor and a 12 tooth pinion. Thanks everyone for your help |
03-18-2010, 06:07 AM | #6 | |
Check your grease and try a battery with more punch. | |
03-18-2010, 01:07 PM | #7 |
Yeah i have considered going to a 3 cell bettery. But many have told me its overkill, im too new at this to know. I own an older 1200 mah 3 cell stick battery that came out of an electric AEG airsoft gun i once had. Dont know how reliable it is or how long it would last. I did hook it up to my LCC once and it was like putting a super charger on it lol! So would a 3 cell give me more torque and speed or just speed? Im guessing both but idk
