03-22-2010, 02:15 AM | #1 |
Newbie Join Date: Sep 2007 Location: Australia
| Will FXR run 3s lipo ?
OK Boys Will the Tekin FXR run 3s lipo ? The manual says that the FXR Pro will. But has anyone tried the FXR. I just smoked my 2s and am thinking about more power. Cheers |
03-22-2010, 02:34 AM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: Hiding in the laundry room!
It will but I believe the recommended motor limit is a 35t I ran a fxr with a 35t and 3s lipo with no issues until I got a Holmes Torquemaster
03-22-2010, 02:36 AM | #3 | |
Quarry Creeper Join Date: Feb 2009 Location: Livermore, CA
Controls: Forward/Brake/Reverse ON Resistance: 0.0012 Ohms Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor) BEC: 6.0V/3.0A Motor Limit: 13 Turn Throttle Profiles: 7 choices on board Reverse Type: 3 choices on board; none, delay, immediate Reverse Strength: 11 steps on board Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor Dimensions: 1.1 x 0.80 x 0.40 " (28 x 20 x 10mm) | |
03-22-2010, 02:48 AM | #4 |
Pebble Pounder Join Date: Feb 2010 Location: Sterling Heights
| Torquemaster? |
03-22-2010, 07:32 AM | #5 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
i think he means that he ran fxr on 3s, then got a HH TM and now runs that
03-22-2010, 07:49 AM | #6 |
Rock Stacker Join Date: Jan 2007 Location: Elk Grove
You may need an external BEC. I switched to 3S with FXR and 55T combo and got some weird stalls. Installed CC BEC and all seems to be ok.
03-22-2010, 02:14 PM | #7 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
Been running an FXR & 55T for several months with zero issues, I do have a Castle BEC hooked up also.
03-22-2010, 02:17 PM | #8 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
Yes the FXR will handle 3S lipo but you will HAVE to install a BEC. The FXR will also handle 4S but is limited to only 55T motors
03-22-2010, 02:23 PM | #9 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Been running a FXR on my berg with two 35t handwound motors for a while now. I do know of a few people running 4s on them with 45t's also with a bigger cap. |
03-22-2010, 02:25 PM | #10 |
45T's??? WOW!! That thing must SCREAM!!!
03-22-2010, 02:27 PM | #11 |
03-23-2010, 12:47 AM | #12 |
I'm running a 65T at the moment and have just added a CC BEC so that side of things are covered . Now time to find me a 3s that fits in OZ. That's the hard part. Anyone tried the turnigy stuff ?
03-23-2010, 12:49 AM | #13 |
Rock Crawler Join Date: Nov 2009 Location: Wasilla Alaska
been running turnigy lipos. Work great. |
