03-26-2010, 09:11 PM | #1 |
Pebble Pounder Join Date: Jan 2010 Location: Moses Lake
| Fx-r overheating
I just moved into the lipo world and popped a 3cell into my creeper with the 55t/Fx-r combo. It is crazy how much power it has now. The problem is the damn thing will over heat in 5mins. I ran my nimh for 40mins and never had problems. I am running stock gearing. do I need to change gearing? any thoughts thanks.
03-26-2010, 09:31 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
Is your motor getting hot too? Or just the esc?
03-26-2010, 09:33 PM | #3 |
Honestly I did not even check the motor so I do not know.
03-26-2010, 09:39 PM | #4 |
03-26-2010, 09:44 PM | #5 |
And if it is only the esc?
03-26-2010, 10:25 PM | #6 |
just went and ran it and it is only the esc that is getting hot!
03-26-2010, 10:34 PM | #7 |
Hateraide Join Date: Dec 2008 Location: Mission BC
if its going into thermal shutdown you need a BEC and that will solve alot
03-26-2010, 10:48 PM | #8 |
I have stopped before it got to shutdown. Any reconmmendations on which BEC will work the best. And is this a common issue, other than the BEC should I change something (Motor)?
03-26-2010, 10:52 PM | #9 |
no just grab yourself a castle creations bec and leave the motor, i had the same problem until i put a bec in and never had the problem again it just allows so not so much draw is being sucked out of the esc which creates it to shutdown |
03-29-2010, 09:47 AM | #10 |
Just got the bec installed and it works great. Thanks for the tips.
