04-10-2010, 07:06 AM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
| rooster crawler and MOA?
Ive searched and have seen "yes it will work" but how , there are only two leads coming off the esc are there two different esc? one for moa and one for a single motor?
05-20-2010, 10:44 PM | #2 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
not sure if you ever found an answer but you would need a punk dig like this: http://www.punkrc.com/index.php?main...products_id=28 The two leads from the rooster go INTO it and it has 4 leads out. 2 for each motor |
05-21-2010, 10:14 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
I used a Rooster crawler ESC on my Berg MOA without a punk dig switch, just takes some creative wiring. I was using a 2 cell lipo and dual 55T novak motors with a mechanical dig switch, here's a couple pictures if it'll help. Not sure which color wire is positive or negative out of the blue and yellow, and I only had red wire at the time to use. Also, if you do wire like this use some "liquid electrical tape" on the splices, it work great. |
