04-10-2010, 09:50 AM | #1 |
Newbie Join Date: Apr 2010 Location: West, Lafayette
| Some SCX10 questions
I have picked up an SCX10 kit and have decided to go with the RC4wd Outcry ESC and RC4wd 35T motor. Since I am a newb and this is my very first scaler I have no clue what pinion to get for this setup. I will be using the Stock SXC10 spur gear. Also the specs on the ESC say :Rated current: 300A forward, 150A reverse. What does that mean? Does that mean that is the maximum that it can handle? I am also trying to decide what battery to get for it. I have a couple of 2s lipos that are 1800 MAH and 20C discarge. Would these work? Take it easy on me please I am a newb to the crawlers and most electrics. THanks Brandon |
04-10-2010, 10:27 AM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
the stock 14t pinion should be fine with a 35turn motor, and i'm not sure if the outcry has a lipo cut-off or not. the site says it's compatible with 2s to 4s lipo but mentions nothing about a cut-off. if it doesn't, you might be able to get an external voltage cut-off or lipo alarm. hope this helps jon |
04-10-2010, 05:46 PM | #3 | |
Brandon | |
04-10-2010, 05:58 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: deroche b,c canada
hi i was running a 45t with 19 tooth on 3cell 11.1. it had good wheel speed and still slow in the trail.
04-10-2010, 06:42 PM | #5 |
04-12-2010, 01:09 AM | #6 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
I would start with a 18t pinion. I would also reconsider the outcry ESC. I don't know anyone one running it personally but I would just have peice of mind goin with a Sidewinder ESC. Alittle more expense but coming from a more reputable electronics company. Nothing against RC4WD, I love their scale products, but I'm not 100% sure about their electronics.
04-12-2010, 04:26 AM | #7 |
Rock Stacker Join Date: Dec 2009 Location: midland
As far as pinion goes, on mine I run a 16t, it is a good compromise. I have good wheel speed when I need it, plus I still have very good low end control. Granted I am running a tourqmaster, but I had very nice control with the sidewinder I used to run too.
04-12-2010, 05:31 AM | #8 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
outcry doesnt have a lvc but a lipo alarm or lvc switch will be great as alreadt stated above! very esc for its price |
04-13-2010, 04:05 PM | #9 |
Well thanks for all of the replies. I had already ordered the outcry so I will let you guys know how well it works. -Brandon |
