04-19-2010, 09:35 AM | #1 |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
| Traxxas 12t titan motor |
04-19-2010, 09:37 AM | #2 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
It tells you what it can handle right in your link. 8.4 volts max. So...No.
04-19-2010, 09:50 AM | #3 |
04-19-2010, 10:17 AM | #4 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
I raced my Slash on 3s (11.1v) for a full indoor season with a Titan 12t. It ran just fine. MOST silver can motors can run on 12v but I don't know about 14.4v.
04-19-2010, 10:35 AM | #5 |
Pebble Pounder Join Date: Apr 2009 Location: Gresham
Currently have one in my LCC and it works fine on 3s (knock on wood). I think the 21t can handle 14v
04-19-2010, 10:44 AM | #6 |
technically any rc motor can handle the 14v the question is how long. even motors rated to 12v wont last as long as on 7.2-8.4. heck i would try it with 14v they main thing is the brushes will wear out alot faster and it will get warmer so just monitor the temps a bit
04-19-2010, 10:52 AM | #7 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
If you looking for a motor that could handle the power you supplying try this Traxxas 775 Motor http://www3.towerhobbies.com/cgi-bin...&I=LXWWG7&P=ML SPECS: Can Diameter: 46.35mm (1.8") Can Length: 67mm (2.6") Shaft Diameter: 5mm (0.20") Shaft Length: 13.5mm (0.53") Input: 16.8V Turns: 10 turns Just make sure you have the ESC that can Handle a 10 turn motor. |
04-19-2010, 02:01 PM | #8 |
Rock Crawler Join Date: May 2009 Location: 354
i guess the other main thing to watch for is your ESC, make sure it can handle 14.4v that you wanted |
04-19-2010, 02:10 PM | #9 |
Quarry Creeper Join Date: Apr 2010 Location: virginia beach
personally the titan 12t motor was fun, but mine just didnt last... i went through 3 since valentines day, now i run BL
04-19-2010, 05:24 PM | #10 |
Yeah ok. But I forgot that if I wire my batteries in parrallel that they will have the same voltage but twice the capacity of a single pack.
04-19-2010, 05:33 PM | #11 | |
Yeah I'm gonna be running this motor in my axial so the 775 size motor would be way to big. I'm getting a xl-5 waterproof esc and 12 turn titan motor. Does any body know what the xl-5 can handle turn wise? | |
04-19-2010, 07:13 PM | #12 |
not sure what turn they can handle, but you will only get bout 30 charges through the motor whether you clean it or not... i recommend something that you can rebuild... but the motor will go and it always happened to me when i was nowhere near the lhs... no problems with esc though...
04-19-2010, 07:28 PM | #13 |
They handle the 12 turn 550 motor, or 15 turn 540 motor....
04-20-2010, 06:05 AM | #14 |
04-20-2010, 06:22 AM | #15 |
04-20-2010, 06:26 AM | #16 |
Bye the way how good is it's bec cause I know it only has a 1a bec but my Novak Rooster Crawler Edition ESC had a 5a bec how does it compare. Will it glitch |
04-20-2010, 07:45 AM | #17 |
Crawler King, i have run an XL-5 with 12t titan motor 18/87 gear on my SCX10 for a while and it has never given me any trouble, it actually worked great, no glitching, heating etc., but I only run a 2s lipo in it, never run your XL-5 on 3s or more than 9.6v nimh or you will see the magic smoke. |
04-20-2010, 11:12 AM | #18 | |
Awsome thanks for your reply. How is the torque on it? I assume it's pretty strong as I've heard people say it has stump pulling power but just want to make sure. | |
04-20-2010, 12:24 PM | #19 |
it's good enough for me, you can also lower your gearing say maybe to 14t or lower it will give you a bit more torque, but like i said it worked great when i had it, lots of mud slinging until I changed to 35t motor on 3s now where talking. Hopes this helps you out. later. |
04-20-2010, 12:36 PM | #20 | |
How is the speed difference between the 12 turn titan and the 35 turn? | |
