04-19-2010, 11:37 AM | #1 |
Pebble Pounder Join Date: May 2008 Location: Vancouver, Canada
| mm and 2 5500kv motors
I am wondering if I can use one mm esc and 2 5500kv motors on the same esc for my clod. I dont know if this is possible or do I need to have 2 mm esc also? Thanks Rob |
04-19-2010, 11:47 AM | #2 |
I assume these are brushless motors by the rating of kv you are using for them, if so then you need one esc per motor.
04-19-2010, 12:09 PM | #3 |
Thanks for the input
04-19-2010, 12:12 PM | #4 |
Quarry Creeper Join Date: Aug 2005 Location: newport
Both sensored, and sensorless brushless ESC's sense the motor's rotor position through electrical feedback in the wires or cable. So you have to run 1 seperate ESC per motor. It would be nice to have a ESC that had 2 ports for sensor cables and you could run a pair of sensored motors, but so far nobody makes one. |
04-20-2010, 06:23 AM | #5 |
Quarry Creeper Join Date: Oct 2007 Location: Ft. Wright, KY
Event if the ESC was capable of running 2 brushless motors you wouldnt be able to run them in a clod cause one would have to spin clockwise and the other counter-clockwise. This is a very good question, I've never thought of this before. Can somebody with some credibility chime in here I'm curious. To me it seems possible... |
