04-28-2010, 09:55 PM | #1 |
Newbie Join Date: Dec 2009 Location: edwards
| metal pinion/plastic spur???
hello, im thinking of getting a 10T pinion metal. and i have a 87T spur witch is plastic My Q is, is the pinion going to eat up the plastic spur? If so where can I get a metal spur? Thanks- |
04-29-2010, 03:54 AM | #2 |
Quarry Creeper Join Date: Nov 2009 Location: gilbert az
No not at all .Actually other way around. I run metal 12T pinion with plastic 87 spur. I used to have a metal spur and it was noisy and wore quick. To me running metal on metal without any sort of lubrication just doesn't make much sence. With the plastic on metal it's quiet and the gears last way longer. By the way, Axial's come with a plastic spur and aluminum pinion from the factory. Jake Last edited by jr104; 04-29-2010 at 03:58 AM. |
04-30-2010, 03:18 PM | #3 |
Quarry Creeper Join Date: Aug 2008 Location: 5280'
05-01-2010, 08:01 AM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
Plastic spur is fine, the important thing is to set the mesh properly, as close as can be without binding. Use a magnifying glass, not a piece of paper! Usually the metal pinion will wear out before the plastic spur. The plastic allows fine grit to be embedded making it like sandpaper, which abrades the metal pinion. Also each tooth on the pinion gear sees a lot more contact than the teeth on the spur. End result - pinions wear out first. I use steel pinions on mine, wear much better than aluminium. Cheers. |
