05-20-2010, 05:25 PM | #1 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
| Dig units?
Can some one please explain the conept of a dig unit? Sorry im a rookie lol. This would of course require a three channel radio right? If you guys have any pics that would be cool too. Thanx. -PileDriver |
05-20-2010, 05:35 PM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
A DIG is a mechanical or electronic device that locks up or freewheels one set of axles. This allows that axle to act as a pivot point so that you have a much tighter turning radius.
05-20-2010, 05:47 PM | #3 |
Dig unit should allow 4wd,front wheel drive only and front wheel drive with the rear locked. Normally you drive in 4wd. Front wheel drive (front dig) with the rear locked or unlocked can be used for many different things. Turning,climbing,unsticking a stuck wheel in a hole,side hills,pushing the front or rear into better position.....are most of the uses you'll see. Lots of practice can show you how beneficial it can be. No crawler or scale truck should be without dig. With a dig set up,you'll see better performance with more wheel speed. Slow set ups will dig decent. A good amount of wheel speed will make your front digs allot better. You'll be able to dig faster and in some cases turn sharper. Last edited by Reflection; 05-20-2010 at 05:52 PM. |
05-20-2010, 06:17 PM | #4 |
Im thinking of running a 35t motor is that good enough for wheel speed? I do need a third channel right? -PileDriver |
05-20-2010, 06:35 PM | #5 |
Pebble Pounder Join Date: Nov 2008 Location: ely
I'm running a 35t epic and its got good wheel speed.
05-20-2010, 06:36 PM | #6 |
Will the dx3e work for the dig?
05-20-2010, 06:38 PM | #7 |
RCC Addict Join Date: Nov 2004 Location: union
05-20-2010, 07:38 PM | #8 |
35 turns are decent. Best if run on 3 or 4 cell lipos geared up a shade.
05-21-2010, 07:57 PM | #9 |
how about the dx5e? wud that work for the dig?
