Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Rock Crawling section 1
Old 01-31-2010, 03:12 PM   #1
Default Rock Crawling section 1
Let me know what ya think...
Kanine38 is offline   Reply With Quote
Old 01-31-2010, 03:29 PM   #2
Default OK, I have it fixed.
http://s756.photobucket.com/albums/x...201%20%202010/
Here is the first section of my Rock Crawling course.
Old 01-31-2010, 05:59 PM   #3
I need to figure out if I'm using going to use styrofoam and shape the rocks with some rhrinoliner to cover it or something else... Any Ideas or have you seen other options?
Old 01-31-2010, 06:45 PM   #4
Not for sure but the rino stuff might give the truck to much traction and cause it not to be challenging or that much fun. Just a thought.
THE PARTS GUY is offline   Reply With Quote
Old 01-31-2010, 07:56 PM   #5
Good point. My wife suggested that i use some pieces of 1/4 split wood and some urethane expamdable foam.
Old 02-01-2010, 06:47 PM   #6
Default Another section
Old 02-01-2010, 06:52 PM   #7
looking good. makita tools... nice
nathand is offline   Reply With Quote
Old 02-02-2010, 04:59 PM   #8
expanding foam and chicken wire makes for a good surface. You can paint it or grade it to get the surface texture desired.
rockcreepin' is offline   Reply With Quote
Old 02-02-2010, 06:04 PM   #9
Great start!!!
d34thw1sh is offline   Reply With Quote
Old 02-02-2010, 08:47 PM   #10
Nice ideas. Chicken wire on top of the plywood or just over the basic frame? I was thinking about styrofoam sheets and carving them to form some rock structures and then adding spray foam to help add some peaks and overall texture.
Old 02-02-2010, 08:55 PM   #11
We made our's with plywood then covered it with quickcrete work's good.
whalebone is offline   Reply With Quote
Old 02-03-2010, 06:04 AM   #12
There more pic's under tri city crawler's in michigan
Old 02-03-2010, 06:42 AM   #13
Try to Bend it
Highlucks's Avatar
expanding foam will work really well, you can even tint it after spraying while its still wet or throw dirt and sand at it to give it a natural look.
Highlucks is offline   Reply With Quote
Old 02-08-2010, 07:36 PM   #14
Default It's growing.
Old 02-08-2010, 07:51 PM   #15
I'm gonna add some chicken wire down to the lower flats. I've seen other guys use bed sheets with concrete to make a natural slope. I think I'm gonna try to use foam sheets to carve a rock section. That's how Wicked RC in Framingham MA did their's. It looks wicked good.
Old 02-09-2010, 01:10 AM   #16
wicked, lol, coasties are funny
autolockguy13 is offline   Reply With Quote
Old 06-06-2010, 05:36 PM   #17
Default Section 1 has first coat of cement
A day of storms is a good reason to finish my indoor course.
Old 06-06-2010, 06:29 PM   #18
Nice job!!! I cant wait til i get my course started
PhantomRS10 is offline   Reply With Quote
Old 06-06-2010, 07:01 PM   #19
Thanks Phantom!
Old 06-07-2010, 05:08 AM   #20
That came out nice.
rob5059 is offline   Reply With Quote
