07-01-2010, 11:45 AM | #1 |
Rock Stacker Join Date: May 2010 Location: sterling
| reverse is faster than forward
ok quick question , why my reverse is faster than forward? i have ax10 with tekin fxr 55t with 87/22 gearing and nimh battery 3000mah with jr radio and reCIEVER
07-01-2010, 11:54 AM | #2 |
You either need to reset your throttle endpoints on the FXR, or you need to adjust the motor timing a bit.
07-01-2010, 11:57 AM | #3 |
how do you adjust the timing???
07-01-2010, 11:58 AM | #4 |
You loosen the two little phillips screws on the endbell of the motor, and rotate the endbell just a bit. Caring for your new Brushed motor This post Caring for your new Brushed motor |
07-01-2010, 12:07 PM | #5 |
oh okay, i thout you will make me find the timing belt.lol i will try that as soon as i gets home |
07-01-2010, 02:42 PM | #6 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
I agree with JRH- reset your throttle trim on your transmitter to neutral and run the FXR initial calibration again...
07-01-2010, 07:22 PM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
There is also "reverse strength" setting on the fxr. If ya got it set up backwards (so forward is reverse and reverse is forward) a lower reverse strength setting could be working when ya go forward. Yes it can be messed up that bad.
