07-01-2010, 10:47 PM | #1 |
Rock Crawler Join Date: Jul 2010 Location: SLC
| which motor...or gears
Just got a scx10 and throttle seems realy touchy for crawling will a differant motor lpe control or should I regear it?
07-01-2010, 11:26 PM | #2 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Depending on the radio that you have you can adjust the punch on it. Or just put a smaller gear (lower tooth count) or a higher turn motor.
07-03-2010, 08:31 PM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Natchez
A better motor or higher turn motor will be smoother on the bottom end . The pinion or spur will help but not as much . Also you can get a better ESC but not sure if you are willing to spend that much money .
07-05-2010, 09:31 PM | #4 |
thanks guys, what "turn" do you recommend and what brands?
07-05-2010, 09:44 PM | #5 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Before getting a motor I would try a smaller pinion. The real problem is the stock esc. I would spend my money there first. Even a rc4wd outcry is an upgrade. Next best budget is the cc sidewinder (even the mirco if ya don't go too low turns on the motor and/or high volts on the batt, but get a bec).
07-05-2010, 10:05 PM | #6 |
sounds awesome but half of it is Japanese, dumb it down for a newb, and post links where to buy thanks! |
07-06-2010, 01:20 AM | #7 |
I googled - rc4wd outcry and the first thing that came up was: http://www.rc4wdstore.com/2/product_...roducts_id=952 I see googleing cc sidewinder doesn't work so well; so here is the castle creations link: http://www.castlecreations.com/products/sidewinder.html The mirco is here: http://www.castlecreations.com/produ...der_micro.html The bec is here (ya don't need the pro): http://www.castlecreations.com/products/ccbec.html Where to buy? TCS, Holmes Hobby, ckrc, a main, stormer hobbies, rc planet are my main ones Do some reading here. There is tons of info available. And don't afraid to search. |
07-07-2010, 10:38 AM | #8 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
You could get an esc/motor combo and kill two birds with one stone. I have the Tekin FXR/45 turn motor combo and it works great. Not too touchy but when you punch it, it has the torque to move your rig very well. The esc in this combo has alot of adjustability when it comes to throttle as well.
