07-01-2010, 11:56 PM | #1 |
Newbie Join Date: Apr 2010 Location: tits
| axial tranni output
im not familiar with the axial tranni but i tried one in my scaler, my rear driveshaft is plastic and has plastic yokes, everytime i try to put the driveshaft set screw on the tranni output shaft it just slides off after maybe 2 minutes of abuse. what has i do to make this set screw hold better? thanks -C
07-02-2010, 12:48 AM | #2 |
Rock Crawler Join Date: Jan 2009 Location: Boise
Are you making sure you are putting it on the flat spot on the output shaft? One thing I did was drill through the output shaft and put a longer set screw in it.
07-02-2010, 06:30 AM | #3 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
Your issue are the plastic yokes and not the output of the transmission. The platic yokes generally do not hold set screws very well. You need to drill the outputs and use screw pins or go with metal outputs alltogether. |
07-05-2010, 09:22 AM | #4 |
Best bet is to just go with metal yokes anyway. That way you can locktite them and they won't go anywhere.
07-05-2010, 09:37 PM | #5 |
Newbie Join Date: Jun 2010 Location: first
