08-03-2010, 08:37 PM | #1 |
Newbie Join Date: Jul 2010 Location: copperopolis
| so i cracked all my wheels
i have an ax10 and i cracked all my wheels they keep expanding and the nut spins inside the wheel. i am alittle strapped for cash i have done some research and seeing that aluminum wheels are the way to go. most of the wheels i saw were around $100 give or take. what are the entry line of aluminum wheels and what are the choices? i was running the axial rockstars with 14oz of lead in the front and 6 oz of lead in the rear with the hb rovers soft Last edited by browningjosh; 08-03-2010 at 08:50 PM. |
08-03-2010, 09:10 PM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Did you strip the wheel hex on the wheel or did you strip the hex on the axle? Do you have aluminum hex's on the axle or plastic? There are so many choices for aluminum wheels out there! Vanquish makes some killer wheels! Eritex makes killer stuff! Look in the wheel and tire forum and look in the vendor forum |
08-03-2010, 09:16 PM | #3 |
RCC Addict Join Date: Dec 2008 Location: pullin somebody else out of a mud hole
check out bad attitude machining has really nice product and good prices , he is in the vendor section under wheels/tires
08-03-2010, 09:21 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Medford, Oregon
A cheap and temp fix is to glue the plastic hex into the rim. Or : JConcepts Tense 2.2 rock crawler wheels - (Black w/ bead locks) (4) http://www.rpphobby.com/product_p/jci3314.htm |
08-03-2010, 09:30 PM | #5 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
$100 give-or-take seems to be fairly standard for aluminum wheels (or machined delrin wheels for that matter). You really can't go wrong with any of the vendors on here though. Just be sure to post pics once you get 'em |
08-03-2010, 10:14 PM | #6 |
The plastic wheels are fine if you don't have the cash for aluminum wheels. The trick to it is making sure your wheel nuts are tight before each run... However, if you are shopping for aluminum wheels, might I suggest buying a star and looking in the 'For Sale' section. It is not uncommon to see aluminum wheels there and you'll likely save a lot more than the cost of the star. |
08-04-2010, 01:02 PM | #7 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
A number of the vendors have the Berg Aluminum wheels available. They're the correct offset for an AX10 and they're $44 for a set of 4. Not the prettiest but they're strong enough. http://www.amainhobbies.com/product_...ad-Lock-Caps-1 |
08-04-2010, 01:12 PM | #8 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
I bought Wheel Works M887's. They have different offsets, look killer, and not bad price. $105 shipped. Check them out!
08-04-2010, 01:15 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
eritex delrin wheels are $65 for a set and from what I hear they are really awesome, and you can get them in different weights!
08-04-2010, 08:39 PM | #10 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
08-06-2010, 10:32 AM | #11 |
| thanks
thanks for all the help. the wheels are cracked themselves. when ever i get into a bind the wheel expands and the hex slips inside the wheel. i really appreciate the help on here the closest shop i have around here is over an hour away. |
08-06-2010, 10:33 AM | #12 | |
08-11-2010, 10:12 AM | #13 |
Rock Stacker Join Date: Aug 2010 Location: Minneola, Florida
did you ever get the wheels
08-11-2010, 10:35 AM | #14 | |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
08-11-2010, 11:02 AM | #15 |
RCC Addict Join Date: Mar 2010 Location: Yelm
08-11-2010, 02:03 PM | #16 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
I have the Mayhem Engineering Double Phattys. I love these things. Dan is awesome. He rushed out my wheels with a temporary set of delrin rings when my engraved aluminum ones were not ready. He did this so I could make it to my first comp all free of charge. The wheels are very versatile and tough. |
08-15-2010, 11:22 AM | #17 |
08-15-2010, 11:23 AM | #18 |
