08-06-2010, 09:27 PM | #1 |
Newbie Join Date: Jun 2010 Location: Australia
| want to build a chassis, help!
hi all, i want to have a go at making my own chassis for my clod axles. just wondering if anyone has some ideas on what to look out for and what not to do. i want a four link set up. i had a go at one before but it was basic and although i got about 100 degrees of articulation it had a lot of torque twist and was basically sh*t. so back to the drawing board.cheers
08-07-2010, 12:06 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Building something like the "NN" chassis would be pretty simple and that chassis works killer for a comp Clod! Or you could do something like the "Stick" or "Pimpcane" for a few bucks at your local hardware store. Both of them are super easy to make. The Stick chassis uses lower links and 2 shocks where as the Pimpcane is just a piece of aluminum channel. Look in the Clod forum and you can get some good ideas.
08-07-2010, 02:11 AM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
Torque twist with clod axles?! It's usually with shafties (without worm gears!) you get that - or so I thought! What exactly was happening?
08-07-2010, 03:04 AM | #4 |
well its not really TT, its more the rear axle pushing the chassis up when the front is up against an object.also when i am full lock turning to one side the two inside wheels would come closer together(i have 4ws) and push the chassis up and over towards the opisite side. the rear would push the front inside wheel up and flip it over
08-07-2010, 03:05 AM | #5 |
Also, 100 degrees of flex is WAY to much! That much flex will be bad for you! And I can say I've never had torque twist with any of my Clods. I don't know how you can have any really?
08-07-2010, 03:06 AM | #6 |
RCC Addict Join Date: May 2006 Location: nor-cal
08-07-2010, 03:10 AM | #7 |
[QUOTE) unlocked diffs?[/QUOTE] I only have the rear locked at the moment.Still waiting on parts from USA.I would have posted a video for people to see and make diagnosis easier but i took it apart in frustration Last edited by clod rider; 08-07-2010 at 03:12 AM. |
08-07-2010, 07:52 AM | #8 |
Do you have a pic of that set up, it might help us see what's going wrong?
08-07-2010, 08:59 AM | #9 |
i dont have pics at the moment.i made something that resembles the NN chassis and worked out my shocks were in the wrong place, i had them mounted in the same place as my top links. the amount of articulation i had has been reduced to just under 90 degrees so now i think i have my problem sorted ill get some pics up soon
08-07-2010, 09:23 AM | #10 |
Cool. Glad you sorted it!
08-07-2010, 02:47 PM | #11 |
Pebble Pounder Join Date: Mar 2010 Location: Jacksonville
It sounds like you had too much anti-squat in the rear. That can cause the rear tires to try and come down and around to the front. Raise your upper links up at the frame end. Also search for threads on anti-squat and suspension geometry.
08-09-2010, 12:25 AM | #12 |
| I only have the rear locked at the moment.Still waiting on parts from USA.I would have posted a video for people to see and make diagnosis easier but i took it apart in frustration[/QUOTE] if you can get some jb weld,it works like a champ |
