08-08-2010, 06:35 AM | #1 |
Rock Stacker Join Date: Jan 2010 Location: england
| novak 55t motor no power
for some reason my novak 55t motor doesnt work what could be the problem? |
08-08-2010, 06:36 AM | #2 |
How old is it? Do you take care of it, maintenance wise? |
08-08-2010, 06:41 AM | #3 |
i bought it second hand so im not sure how old it is
08-08-2010, 11:28 AM | #4 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
....if you haven't already done so - check to see if your ESC is indeed working. Easily done by attaching a motor that you know works for sure. Just my 2 cents - 55t motors aren't easily burnt out w/normal use.
08-08-2010, 11:44 AM | #5 |
What trouble shooting have you tried? What electronics setup?
08-08-2010, 01:46 PM | #6 |
im runing a ansmann 12tesc which works fine and a traxaxs tq3 radio i have tryed putting the battery straight to the motor and still no power and the battery is fully charged |
08-08-2010, 02:28 PM | #7 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Check to make sure there isn't anything in the motor, screw, washer, nut, ect.... I know I have sat a motor down more than once on the work bench and the motor sucked something in it! Pull your brushes and check them. Also take a look at your caps and see if they are good. Have you asked the seller who you got it from about it?
08-09-2010, 01:56 AM | #8 |
ive checked all that its alll ok by the looks of it
08-09-2010, 02:05 PM | #9 |
Brushes super short? Springs that holds the brushes in place bottoming out in the slot? Commutator could be toast, and in need of a cut to get it all good again (maybe). If you kick it, does the truck move again? |
