08-17-2010, 11:42 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: almuņecar- espaņa
| Engine for my pangolin
My car has an engine of 55t. That was spending if I put one 27t .el car runs mas but can it rise less?. Or it is all the same
08-17-2010, 11:48 AM | #2 |
Rock Crawler Join Date: May 2009 Location: 354
i'm not sure if this is what your asking for, but here it is. The 55t will have less wheelspeed but more torque compare to a 27t, but proper gearing and the right voltage and you will be happy with it. Hope this helps on that note some of the guys in our group are running 55t on 3s lipo and have tons of torque and a pretty good wheelspeed as well. |
08-17-2010, 12:12 PM | #3 |
It is possible to walk well with a 27t and one pine kernel of 17 teeth for a crawler
08-17-2010, 02:30 PM | #4 | |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
I would drop to a 13 to 15 tooth and I think you'll be happier i.e. more torque and more controll at low speeds but still some good wheelspeed when you need it. Or just upgrade to 3 cell Lipo batteries with your 55t, as someone mentioned already, and you'll get the same effect but longer more steady run times. | |
08-17-2010, 02:35 PM | #5 |
Ok thank you very much and left the engine 27t and one pine kernel of 14 to try
