09-13-2010, 10:15 PM | #1 |
Pebble Pounder Join Date: Sep 2010 Location: Topeka
| Shafty torque twist questions..
Ok, I have an MRC and know all about torque twist on this little bugger.. It leads me to ask this in depth question: My MRC spins both driveshafts the same direction, and every aftermarket tranny & T-case I've looked at does the same... Why don't transfer cases/trannies have counter rotating output shafts for the front and rear differential? It would in theory help to cancel out some of the unwanted TT we deal with. It would offer the benefit of loading the differentials in the preferred method causing rotational down force on the tires front & rear. In current setups one diff has down force, the other has lift from the torque effect. The differential would need to be flipped over, hub to hub, on 1 end of the rig, and you could do it so that you "clock" the diffs in the right way to create mechanical (rotational) down force on the tires. Obviously it would be another gear in the tranny/transfer case, but I think it would be for the better. Trade a possible small hit in durability for the advantage of negating most if not all TT from the setup. I know most/all shaftys use basically the same axle case front and rear, and the mount locations would likely be fubar and clocked into the wrong positions, thus making the manufacturers (or aftermarket) have to create a mirrored casing to allow proper geometry. Is the reason this hasn't been done cost? Or are there flaws in my logic? ~Kev |
09-13-2010, 10:47 PM | #2 |
Well if you do a proper four link it will take care of 95% of the TT you have on your MRC...I think that is a better solution |
09-14-2010, 12:11 AM | #3 | |
09-14-2010, 07:54 AM | #4 |
Rock Crawler Join Date: May 2009 Location: 354
limit your shock, as above said 4 link, move your electronics lower instead of top center. This will almost eliminate your TT, best thing is, it's free Hope this helps |
09-14-2010, 09:09 AM | #5 | |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
I think you are right in most of your thinking, it does seem logical, and I believe it would work in some situations. The problem is that it relies on equal torque at both axles to balance out, but that is not reality. Torque only goes where the traction is and is rarely balanced front and rear, and so you will still see the effects of torque twist, just that one end will be opposite to what it used to be. This has been tried, there's pics of it somewhere on the forum. I think it was egressor, and if I recall correctly, he took it off again. After a brief search my new ax10 chassis Cheers. | |
