09-14-2010, 11:39 AM | #1 |
Newbie Join Date: Aug 2010 Location: Stoke-on-trent
| torque twist
Hi all does anyone no how to prevent torque twist on an axial ax10. Thanks in advance Dave |
09-14-2010, 12:37 PM | #2 |
Quarry Creeper Join Date: May 2010 Location: South Central AR
Go to AX 10 section and search torque twist. You can learn alot with the search function on this site.
09-14-2010, 03:52 PM | #3 |
There's a tips-n-tricks sticky at the top of this forum. In there is a bunch of useful info including a link to a thread on torque twist. RCCRAWLER tips, cheap tricks / parts guide. |
09-15-2010, 09:52 PM | #4 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
flip the tran around if you havent already, also witchever tire in front that lifts when crawling up a steep grade. Put a coilspacer on the rear upposing shock. Try wieght and tuning with shock oils and coil angles and so on. You will find asetup that fits you and prevents torque twist. when I had a AX10 I had it setup good, but the torque twist was still there. Just not as harsh.
