10-06-2010, 08:11 PM | #1 |
Rock Crawler Join Date: Oct 2010 Location: pickens county
| Wil i be to low?
Question I have a ax10 scorpion and im changing the gear ratios. The spur gear from an 87 tooth to a 89 tooth, changing the gear on the motor from a 14 tooth to a 10 tooth, changing the 27t motor to a 55t, and finally changing the axle gears from 38/13s to 43/13s. Is there anyone who has this setup?
10-06-2010, 08:20 PM | #2 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
A 55t with 10/89 gearing is going to be slow, especially with the new axle gearing. What voltage are you running? It's going to be pretty darn slow if on 6 cell, but you'll get years of runtime...
10-06-2010, 08:24 PM | #3 |
I'm running a 7.2v batt
10-06-2010, 08:32 PM | #4 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
That thing will be crazy slow! Keep the 27t if ya go with that gearing!
10-06-2010, 08:40 PM | #5 |
Well I already ordered the 89th spur gear and pulled out the 27t motor. I may just stick with the 89th spur and a 55t motor
