10-20-2010, 12:54 PM | #1 |
Newbie Join Date: Oct 2010 Location: Lakeland
| turning radius
Any ideas on how to increase the turning radius of the HPI Crawlerking. I would like to turn sharper since most of my time is spent running around the yard.
10-20-2010, 01:23 PM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
Open up the diffs if your kit came with spider gears put them in. If you only have 1 set put it in the front.
10-20-2010, 01:28 PM | #3 |
If you want to turn sharper, then you would want to decrease the turning radius. Does the front axle use dogbones? If so, you can grind down the cup for more clearance. Also, make sure that your servo is giving full throw.... |
10-20-2010, 05:25 PM | #4 |
Dumb me. Yes decrease the radius. Thanks for the advice, i'll have to give it a try ,and check the throw.
10-23-2010, 11:54 AM | #5 |
Newbie Join Date: Aug 2010 Location: spok
yep, throw ia where it is at.cheers, b
10-23-2010, 12:48 PM | #6 |
2 other options... • Does anyone make a dig for that truck? • You could make it 4WS. |
