11-17-2010, 12:47 AM | #1 |
Rock Stacker Join Date: Oct 2010 Location: SLC
| shock fix
i have a set of factory axial shocks and the cap and the body keep pulling apart. i kinda like how they have been performing since the new springs. i have looked around and it seems common every one says buy new ones, but im not going to do that until its time for a new chassis. at the moment i dont want to replace, are there any fixes the keep them from doing that? thanks |
11-17-2010, 02:37 AM | #2 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
CA glue or some two part epoxy. They probably wont come apart again though. I've used thread locker to some success if you have aluminum bodies and a bit of red thread lock on plastic bodied shocks.
11-17-2010, 03:20 AM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
The traxxas aluminum caps work great. The only problem is the traxxas caps dont have the same mounting.. Check them out at your hobby store you will see.
11-17-2010, 06:31 AM | #4 |
Put a zip tie around the cap.....
11-17-2010, 09:28 AM | #5 |
i will give those a try thanks
11-18-2010, 01:28 AM | #6 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Try thred tape wrapped around the threded portion of the shock body before you replace the cap.
