01-16-2011, 03:32 PM | #1 |
Newbie Join Date: Jan 2011 Location: Columbus
| Best Axle
Im looking to replace my rear axle I stripped the gears today. I have heard Axial has some of the best axles. Should I buy the axial or replace the gears in my current axle? An suggestions help
01-16-2011, 03:36 PM | #2 |
What axles do you have? You really don't need to throw on an Axial axle if you don't swap out the other.....could be different gear ratio and width.
01-16-2011, 03:37 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I tried the mind meld thing, but could not determine what your current axles are.
01-16-2011, 03:38 PM | #4 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
The Axial drive line is very durable on most any scale or crawler setup . ?The problem with giving you a good answer is we don't know what you are currently running.
01-16-2011, 04:18 PM | #5 |
sorry its the trex 60
01-16-2011, 06:47 PM | #6 |
Newbie Join Date: Jan 2011 Location: West Point
Hey guys, This is my rig actually I got the trex d60 axles and the rear is stripped, the front also has a slip it seems I want to uprade I would like to get something worth having not something i have to replace everytime i go out. So give me some ideas thanks. I just got this rig and only took it out about 3 times before i stripped these axles. |
01-16-2011, 07:03 PM | #7 |
Rock Crawler Join Date: Oct 2010 Location: pickens county
Well I run axial axles and have never had a problem with them, and I've found several sets on ebay for around $88 which is well worth the money in my opinion
01-17-2011, 11:41 AM | #8 | |
Rock Crawler Join Date: Jun 2010 Location: SENECA
01-18-2011, 08:38 AM | #9 |
01-18-2011, 09:01 AM | #10 |
01-19-2011, 09:39 AM | #11 |
Yeah it is so Im looking for the best axles that are not moa. Thanks |
01-19-2011, 10:01 AM | #12 |
Axial axles are considerably wider than the Trex... What part are you breaking? The ring or pinion gear? It is quite possible that you need to properly shim the pinion gear to get good contact with the ring gear (or vice versa). Here are the replacement parts that you need to fix yur truck: http://store.rc4wd.com/STEEL-BEVEL-O...-60_p_348.html http://store.rc4wd.com/Heavy-Duty-Sp...xle_p_998.html |
02-06-2011, 03:46 PM | #13 |
Ok guys so I rebuilt these axles and now the housing broke. Need to know what yall think get new housing or something else. These are on an RC4wd T-finder frame.
02-06-2011, 03:48 PM | #14 |
O yeah I just stretched and widened this thing and it just doesnt seem to be holding up. thinking of building whole new rig so may repair this thing with new housing and put back to stock and sell.
