01-21-2011, 07:14 AM | #1 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
| CC BEC wiring question...
The yellow signal wire does not need to be attached to the receiver, correct? I have the BEC soldered to the power lead for the esc, and will use a female/female socket to plug the 7950 into the red/black of the BEC. The BEC's yellow wire will not go past that junction, the servo's yellow wire will go to the receiver's steering channel. I saw a Dual ESC MOA diagram where both ESC'c red wire had been pulled, and the BEC was feeding power to/through the Rx. Since I'm going to push 7.4V to the 7950, I want the BEC wired direct to the servo so the Rx doesn't have that much juice to it. I will leave one ESC's red wire plugged in to power the Rx. I think I have this right, just want confirmation that the BEC signal wire is only used for prgramming when attached to the Castle Link. |
01-21-2011, 07:20 AM | #2 | |
01-21-2011, 07:28 AM | #3 |
Thank you, sir. Can you make it this Sunday? |
01-21-2011, 09:06 AM | #4 |
Rock Crawler Join Date: Aug 2010 Location: Socal
Thats how I wired it on my shafty. Obviously with one ESC though |
