01-24-2011, 08:14 PM | #1 |
Newbie Join Date: Jan 2011 Location: Tri-cities
| Plz help me out
Hi i am pretty new to crawling and i recently purchased a losi comp crawler and installed a rooster crawler esc and a 65turn integy motor.for my battery im running a 7.4volt 2000 mah lipo but i feel like my truck has no tourque. I was wondering if anyone could point me in the right dierection to get more tourque out of my set up?
01-24-2011, 08:26 PM | #2 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
Get rid of that integy and get something like a tekin or somethine long that line
01-24-2011, 08:28 PM | #3 |
| Help
What would be a good brushed motor to run?
01-24-2011, 08:35 PM | #4 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
I run integy 35t in my losi and can snap v2 axles pretty easy . I think hes probably binding up somewhere. A 65t has tons of torque but no wheel speed . Check your gear mesh,loosen the motor and try and spin the trans by hand (it should spin with minimal effort) and check for binding down the line. You can cook your electronics if your constantly binding up your rig.
01-24-2011, 08:50 PM | #5 |
| Its not binding
I thought it was the gear mesh at first but it wasnt. the motor turns easy and is litteraly brand new and the trany spins easy also it is doing alot of jumping and the steering jerks around. I think it might be my esc but im not shure. Cus i know with this set up it should have all kinds of touque but it just stops when i start crawling up something the motor just stops turning
01-24-2011, 09:00 PM | #6 |
what radio are you running?
01-24-2011, 10:37 PM | #7 |
Quarry Creeper Join Date: Feb 2009 Location: ewetah
what radio and servo you using, and do you have a bec? Have you calibrated the radio to the esc?
01-26-2011, 04:13 PM | #8 |
Newbie Join Date: Jan 2011 Location: somewhere
try a 55turn
01-26-2011, 05:44 PM | #9 |
Quarry Creeper Join Date: Jan 2011 Location: Spokane
I would suggest a 45t or 35t
Tags |
plz help |
