01-27-2011, 06:43 AM | #1 |
Rock Stacker Join Date: Feb 2010 Location: buffalo
| holms hold ?
(problem)rear seams to stall bad what is a good % to start out with when using the holms hold. and if it is set at 100%would that create rear stall? i am running 2 br-xls, only have the hold turned on in the rear could i turn up the throttle curve in the rear? -4pl radio -2x45t intigey -2x br-xl -cc bec -xr-10 sorry if i did not give enough info still new to this . |
01-27-2011, 08:14 AM | #2 |
The rear motor is stalling under throttle and load? The drag and hold will not affect this. I would suggest dropping your pinion down a tooth in the rear, and maybe add a bit of forward timing to the motors if you don't have some already.
01-27-2011, 08:25 AM | #3 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I haven't needed to use more than 30-40% on the Holmes Hold to achieve great results.
01-27-2011, 09:48 AM | #4 |
yes ,the rear motor is stalling under throttle and load but it is more noticeable under load . how do i add timing?
01-27-2011, 10:37 AM | #5 |
Rotate the endbell a bit. Not familiar with brushed motors? Second post will be a visual representation Caring for your new Brushed motor |
01-27-2011, 10:46 AM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: Rocklin
Start your timing at 5-7 degrees and drop a pinion size in the rear like john said.
01-27-2011, 11:11 AM | #7 |
thanks for the help......learning every day!
01-27-2011, 11:25 AM | #8 |
First thing I would do is make sure your throttle positions have been timed together on both ESC's with the radio.
01-27-2011, 11:41 AM | #9 |
01-27-2011, 11:56 AM | #10 |
| You didn't program the throttle position when you installed them? Then this is most likely the cause of your problems. I believe with the BR-XL you need to hold the throttle in when you plug in the battery or turn on the switch. You should do this to both ESC's at the same time. I do not suggest running different pinion gears with dual ESC's setups. |
01-27-2011, 12:10 PM | #11 |
i will try that first all i did was plug them in and drive
01-27-2011, 12:24 PM | #12 |
You may have good luck doing this to both ESCs at the same time, but if you have issues getting one to sync you will need to make sure that the ESCs are not hard wired together before trying again one at a time.
01-27-2011, 01:46 PM | #13 |
| You always need to calibrate your radio to your ESC, no matter the brand. You may have never noticed it with a single ESC setup but you very likely lost performance in a previous setup by not doing that.
01-28-2011, 08:28 AM | #14 |
thanks for the help after a bit of all the suggestions it seams perfect. let me hit you with another question i am sure Harley has the answer can i adjust the % of power to the front axial the same way as the back? |
01-28-2011, 09:51 AM | #15 |
| By overdriving the rear you essentially are doing the same thing. No need to control each independently.
