01-30-2011, 11:32 AM | #1 |
Rock Stacker Join Date: Sep 2009 Location: Alberta
| Aluminum Ax10 bodies
Ok maby im tired or just too stupid to figure this out but does the axial aluminum shock bodies (55mm i think) swap right into the stock plastic ones. I couldnt find any part numbers for the rest of the aluminum shock. Thanks |
01-30-2011, 04:35 PM | #2 |
I can't answer your direct question. I will say, why not swap the complete shock and be done with it?? |
01-30-2011, 04:44 PM | #3 |
I was under the assumption that I could swap the entire shock assembly (asid from the body) from my plastic ones to the aluminum bodies but I cant get it to work. I couldnt find a seperate assembly kit for the aluminum bodies only either plastic kits or full aluminum kits (with alu shock caps etc). I got 4 for x mas so I hope I can do SOMETHING with them lol.
01-31-2011, 12:30 PM | #4 |
Bomp?
01-31-2011, 01:25 PM | #5 |
Axial makes two different shocks, one is a 4" comp shock and the other is the longer stock length AX10 shocks. The short body will not be interchangeable with the stock length AX10 shocks.
