02-02-2011, 06:54 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Not Sure
| SCX10 Axle Upgrades/ Mods
I have an SCX10 Dingo and looking for good upgrade/ mods to do to the axles for a little more durability and strength. Any suggestions or mods out there that you guys know of?
02-02-2011, 06:59 PM | #2 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
KC Jones and Gunners axle toobz Best axle mod I have done so far. |
02-02-2011, 07:01 PM | #3 |
These are some of the most common: Aluminum knuckles - Axial, VP, HR, STRC, etc. Aluminum c hubs - same brands Axial HD 43/13t ring and pinion up front Gunnar Toobs Super 300 axle shafts Last edited by ittybitty; 02-02-2011 at 07:07 PM. |
02-02-2011, 07:30 PM | #4 |
how do them toobs work man? The actual axle shaft itself slides through them? so these basically just reinforce the mounting of the c?
02-02-2011, 07:50 PM | #5 |
Yes.... The set I got worked perfect and easy to install
02-02-2011, 08:09 PM | #6 |
do the stock axles just slide right into them and that is it? No special shafts needed or mods to the stock shafts required?
02-02-2011, 09:30 PM | #7 |
Yes the stock shafts work with them with no mods. The only thing that would require any modification is if you are running the Vanquish knuckles if I read it correctly. Not only do they reinforce where the hubs attach, they provide rigidity to the housing, and also add weight where it's needed...down low and out of the wheels.
02-02-2011, 09:40 PM | #8 |
cool beans man, thanks. what are the advantages to the stock shafts compared to like CVD axles? can you axplain the differences between the Vanquish knuckles and the aluminum Axial knuckles as well by chance?
