04-07-2006, 11:15 PM | #1 |
Newbie Join Date: Oct 2005 Location: With your Mum!
| Which ones better? |
04-08-2006, 12:01 AM | #2 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
| TowerPro MG995 208 oz/in torque @ 6.0 volts .13 sec/60 degrees @ 6.0 Volts HiTec 645MG 133 oz/in torque @ 6.0 volts .20 sec/60 degrees @ 6.0 volts You get a free key chain with the auction for the 995 |
04-08-2006, 12:56 AM | #3 |
What about TowerPro MG995 or Hi Tec HSR-5995TG |
04-08-2006, 05:27 PM | #4 |
Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
alot of people are running the towerpro so for the price i would get one of them.
04-08-2006, 06:56 PM | #5 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
| Hitec Product Specs Just look at the specs of the servos in question, then compare the prices................the decision is up to you. |
04-08-2006, 07:00 PM | #6 |
I'm running the Tower Pro MG 955 in my super crawler (2) and my 2.2 (1) and to this point I've had no problems. That being said the Hi Tech 645 seems to be the standard issue crawling servo and work very well. |
04-08-2006, 08:49 PM | #7 |
Well i got a tower pro MG 995 but its piss weak. it won't turn the wheels. here some crawler specs 17' wheel base moab XL maxx arm lock out. |
04-08-2006, 08:54 PM | #8 |
There are two versions of the MG 955, You may have got the high speed instead of the high torque.:?
04-08-2006, 08:58 PM | #9 |
nope i am pretty sure its the high torque version because its pretty strong but dosen't want to turn the wheels.
04-08-2006, 09:03 PM | #10 | |
Pebble Pounder Join Date: Dec 2005 Location: Albuquerque
04-08-2006, 09:06 PM | #11 | |
Dimensions: 1.57" x 0.79" x 1.44" (40 x 20 x 36.5mm) Weight: 1.78oz (48g) Operating Speed (4.8V no load) : 0.17sec / 60 degrees Operating Speed (6.0V no load) : 0.13sec / 60 degrees Stall Torque (4.8V): (13kg/cm) Stall Torque (6.0V): (15kg/cm) Temperature Range: -30 to +60 Degree C Dead Band Width: 4usec Operation Voltage: 3.5 - 8.4Volts **HIGH SPEED** Dimensions: 1.57" x 0.79" x 1.44" (40 x 20 x 36.5mm) Weight: 1.78oz (48g) Operating Speed (4.8V no load) : 0.12sec / 60 degrees Operating Speed (6.0V no load) : 0.1sec / 60 degrees Temperature Range: -30 to +60 Degree C No torque listed | |
04-08-2006, 11:16 PM | #12 |
i got the top one
04-08-2006, 11:38 PM | #13 |
I think you might want to check the BEC rating of your ESC. Make sure it is supplying enough power to the servo. It is rated at 200 oz. at 6 volts.:?
04-09-2006, 02:01 AM | #14 |
Quarry Creeper Join Date: Nov 2005 Location: fairfax
i've read some not very good things about the TOWERPRO servo. you really should read this thread: TowerPrg MG995 seems if you order two you might get lucky enough to get one that will work for more than a week. and they take a long time to get. for the headache that comes with the TOWER servo i would have to say just get the HITEC |
04-09-2006, 02:05 PM | #15 |
I've read it and posted several times. So far I'm a month in. 1 COMP (2nd overall) 2 GTG's and numerouse practice runs and they are both running great. So I guess I'm lucky?
04-09-2006, 03:10 PM | #16 |
yeah i was gonna jump on some of these servos but as that thread progressed i lened away from them more and more. you have had no problems with yours huh? maybe i should just buy some and see. the price is deffinately right |
04-17-2006, 10:08 PM | #17 |
Rock Stacker Join Date: Mar 2006 Location: San Mateo
I'm gonna get one and if it doesn't break, i'll get another! btw here is one that ships from the US instead of Korea Last edited by CreativeSN; 04-17-2006 at 10:17 PM. Reason: adding link |
04-17-2006, 10:23 PM | #18 |
Several sessions, gtg's and a comp and not a single problem to this point! Put one in the 2.2 TLT and I'll do some more "testing"! |
05-03-2006, 09:19 PM | #19 |
those finally shipped out and they are actually coming from HONG KONG. only $17 though
05-04-2006, 08:47 AM | #20 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
I am with DEZ, I got lucky bought two for a TXT Basher and have had zero problems. They look like cheap re-babdged Futaba's.
