02-28-2011, 07:07 PM | #1 |
Rock Stacker Join Date: Sep 2009 Location: antioch
| burg or bully, ???
whats the differance between the burg and bully axails ? i havent read about anyone haveing to do much to ther bully axial but the burg i keep reding about grinding, clocking(dont know what that is yet) different stuff with the motor mounts. i would like to try my hand at a moa and compet at the locol hb shops. never built from ground up before, and i realy like the t1erc rock show chassis , how do i figure out the link lengths i would need ? thanks for all help
02-28-2011, 09:05 PM | #2 |
Pebble Pounder Join Date: Apr 2010 Location: CSRA
You will find that is like asking if a chevy is better than a ford. Opinions vary. I had Bully "axles", but sold them and bought "Berg". For bashing bully axles are great. For competing, bergs are better IMO. You have to make a lot of decision before getting in to link length. Start with axles, chassis, electronics (esc, dig, bec, motors, etc) and then start to think about links and so forth. Buy a star, surf the classifieds and find yourself a nice used berg. Takes a lot of the guess work out and gives you a good starting point. You will figure out pretty quickly what works and what doesn't. |
03-01-2011, 04:50 PM | #3 |
thanks for the info, |
03-01-2011, 05:05 PM | #4 |
Pebble Pounder Join Date: Apr 2009 Location: Utah
Gotta represent Bully's! Ha ha, only axles I've ever owned. |
03-01-2011, 07:25 PM | #5 |
Rock Stacker Join Date: Feb 2011 Location: inman
you see alot of burgs and xrs at comps and not many bullys. gotta mean something.
03-01-2011, 10:52 PM | #6 |
Quarry Creeper Join Date: Dec 2006 Location: Tasmania
03-01-2011, 11:35 PM | #7 |
Pebble Pounder Join Date: May 2009 Location: farmington crawler capitol
Having owned both I would go with Berg/NewAge the're the smart choice
03-02-2011, 07:43 AM | #8 |
I have owned and competed with both. My bully has seen a LOT of abuse and never broke a SINGLE part....stock. They are heavy and take a bit of work with the dremmel to get the most out of the steering, but other than that, they are a great set of axles. There are quite a few guys down here that run Bullys and they perform well. I have been driving my berg lately and it drives nicely, I'd say better than the bully.....but it needed a TON of upgrade parts to get it comp ready. Hell, I broke a stock axle within 1 minute of this trucks first run.... So, it all comes down to personal preference. Do you want a set of axles that are fairly inexpensive, can take a LOT of abuse in stock form and perform decently? Then go with the Bullys. Do you want a set of axles that are rather costly and require a lot of upgrades but are lighter and perform flawlessly (after the upgrades)? Then go with the Bergs. Just because you don't see lot of folks driving the Bullys doesn't mean that they are inferior.... |
03-02-2011, 07:54 AM | #9 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
Bergs out of the box are not the most durable axles on the planet what most people do its replace the third gear and replaces the shafts with super 300's and then they are more durable at a comp with someone running a stock berg they broke 2 shafts on 2 cources (1 on each) and they wer not in a bind Bullys on the other hand are all most indestructable and they really only needs some lightening the bullys are a lot heavyer then the bergs if you want a set of axles that are cheap (Bullys) if you want a set that performs better then but need upgrades (Berg) Last edited by asw27x; 03-02-2011 at 07:58 AM. |
