03-01-2011, 07:40 PM | #1 |
Newbie Join Date: Jan 2011 Location: Altus
| axial tranny
My transfercase out put shaft on the back broke of tonight its the regular stock trany that came on the rtc. and i was wondering if i could just buy the out put shaft or if i had to buy a whole new transfercase?
03-01-2011, 07:52 PM | #2 |
You can get new outputs. Skip the stock replacements and go with some steel units. Here's what I'm using... http://www.rpphobby.com/product_p/rrp1542.htm Last edited by Duuuuuuuude; 03-01-2011 at 07:54 PM. |
03-01-2011, 07:57 PM | #3 |
will that go on my transfer case without me haveing to do anything else to it
03-01-2011, 08:00 PM | #4 |
Yup. Open the case, pull the bearings off of the old outputs/gear, put them on the new one, put a little grease on the gears, then put it back together.
03-01-2011, 08:01 PM | #5 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Pretty much, just take the tranny apart and install the new gear. FWIW I run the same gear. |
03-01-2011, 08:05 PM | #6 |
oh ok thanks
03-02-2011, 10:39 AM | #7 |
Newbie Join Date: Feb 2011 Location: Hazen
Dose anyone know to to replace the output shafts on an Axial SCX10 tranny? I dont want to take the whole thing apart, just wondering if thier was an easy way of replacing them.
03-02-2011, 11:06 AM | #8 |
You have to take the transmission apart. There is no other way.
03-02-2011, 11:28 AM | #9 |
03-02-2011, 11:50 AM | #10 |
| Ah...thats where I was screwing up. I drank the beer, not offered it as sacrifice/bribe/motivation to the rig itself.
03-02-2011, 12:03 PM | #11 |
03-02-2011, 12:10 PM | #12 |
Jeep whore Join Date: Aug 2008 Location: Florida
03-02-2011, 02:39 PM | #13 |
03-02-2011, 03:23 PM | #14 |
Rock Crawler Join Date: May 2009 Location: 354
yeah in this hobby you need to learn how to build and re-build your tranny,axles and what not otherwise you'll be spending a whole lot of money replacing the whole thing everytime something breaks |
03-02-2011, 07:35 PM | #15 |
i have the manual that came with it. and what kind of grease do yall use on these axles and trannys
03-02-2011, 07:48 PM | #16 |
ask a 100 people, you'll get 100 different answers lol. everyone has there own grease they like, while others despise it. i personally like "lucas red n tacky" ive been using it for a year or 2 and havent had a problem.
03-02-2011, 07:56 PM | #17 |
ok how often am i suposed to take it all apart and regrease it all
03-02-2011, 08:22 PM | #18 |
If you don't run it in water, maybe once or twice a year.
03-02-2011, 09:01 PM | #19 |
mine has never been through water. and i have some integy shocks i was wondering what kind of shock oil do i need to run.
03-02-2011, 09:03 PM | #20 |
What kind of shock oil, or what weight? All shock oil is essentially the same. The weight is up to you. Search around and see what others are using in rigs comparable to yours. |
