03-06-2011, 07:28 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| 1st crawler bully 2.2 HEEELLLLPPPP
What size lipo battery do I use? mah and s What is clocking? Where is a good place to put the battery? What pinions do I use? What shock oil should I use? All of the stock oil leaked out. |
03-06-2011, 08:28 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
Need some more info. What motors are you running? what chassis are you using? Are you using two ESC's or one ESC with a dig unit? Clocking is the position of your axle/motor, longer upper links will clock your axle negative in most cases. Longer lowers will clock it positive, in relation to the location of the c-hubs. Shock oil, I would start with 30wt and drive the rig and see how it works. This can be changed a 100 times until you get it how "you" like the way it handles and reacts on the rocks. First you need to fix the leaky shocks. |
03-06-2011, 09:11 PM | #3 |
I have the stock 45 turn rc4wd motors, bully chassis. One outcry fan cooled dual motor esc with a homade microswitch dig. I filled my shocks with 30 wt and wrapped the caps with teflon tape before reassembly. I hope they are sealed now. Have not had a chance to try them out.
