03-27-2011, 04:36 PM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: stephens city
| Tube frames and cages
What kind of material do you use to build the frames and the cages? What do you use to weld it together? Sorry I'm new to this and want to start a project. Thanks for the help.
03-27-2011, 05:44 PM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
To answer your question. The material used to make the tube work will generally be un-coated steel Brake line (3/16) or solid steel rod and it is usually brazed. But if you had scrolled down a bit you would have found this sub-forum http://www.rccrawler.com/forum/tools-procedures/ It's called tools and procedures. Also the search feature is there for a reason. If you search for Brazing, it will bring up how to do it. Have fun. |
03-27-2011, 07:11 PM | #3 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
I use 3/16 brakeline. I weld mine.
03-28-2011, 09:10 AM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: another state of mind..?
STEEL, ALUMINUM, BREAK LINE, CARBON FIBER FLUX CORE, MIG, TIG, BRAZED, SCREW, EPOXY this is the newb corner so he hight not know about search just yet or he might be like me... lazy |
04-01-2011, 07:50 PM | #5 |
Thank you for your reply's.I am new to this and didn't know about the search engine sorry.
04-01-2011, 08:08 PM | #6 | |
Pebble Pounder Join Date: Apr 2010 Location: CSRA
If you are irritated by questions that can be found by searching, stop reading the newbie section | |
04-01-2011, 08:32 PM | #7 |
dont be sorry thats way you posted hear i hope to see what you come up with. |
