04-05-2011, 12:56 PM | #1 |
Rock Stacker Join Date: May 2010 Location: Canada
| Pinion for 35t Motor
I was thinking of changing out my Axial 27T in favour of a Tekin 35T motor. Would the stock pinion I have on the 27T be a good match for the 35T? If not what pinion would you guys recommend? I am running the newer stock Axial ESC with drag brake and 2S 40C 4000 LiPo's. This is also on an Axial SCX-10 Honcho. Thanks in advance.
04-05-2011, 01:13 PM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
I ran a 14t pinion in my SCX10, and a 35t integy motor, with good luck. Pinions are inexpensive and worth the experimenting. I like to start small and work my way up.. |
04-05-2011, 01:20 PM | #3 |
Thanks for the reply. Were you running it on 2S or 3S?
04-05-2011, 04:40 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
I would suggest start at stock gearing and then gear to heat. As long as you keep you motor temps under 70*c, it will be fine..
