04-13-2011, 09:58 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: Manitowoc
| fx-r esc
plz help new to brushed motor do i need to use a capacitor on the fx-r with a bec or can i get away not using a capacitor
04-14-2011, 12:53 AM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Yes you need the cap no mater what. It is in the instructions that come with the ESC. It's part of the design for the ESC and is required. Don't take this the wrong way but if you had done a 30sec search in this very forum you would have found this: how important is the capacitor for the fxr? |
04-14-2011, 04:44 AM | #3 |
Quarry Creeper Join Date: Nov 2008 Location: Natick
X2 on CAP's !!! You must run them or risk letting the magic blue smoke out of the box! That would be an expensive mistake. |
04-14-2011, 09:15 AM | #4 |
Well i had a guy from a hobby store wire it up and he never put it on and he put heat shrink on the wires so were could i even hook it up or so i have to cut it and redo the wiring
04-14-2011, 09:24 AM | #5 |
their is a still a little post left that i could put the cap onto but i did know if it still would work
04-14-2011, 10:14 AM | #6 |
Take off that heat shrink. The solder posts do double duty as heat sinks for the FETs.
04-14-2011, 10:25 AM | #7 |
So i dont need the heat sink at all and should i just resolder so i can put the cap on because i really dont understand what u meant
04-14-2011, 05:01 PM | #8 |
What Arecee is saying is that the solders posts on the FX-R ARE heat-sinks. (which was slightly off topic hence confused you) So cut off the heat shrink and solder it on...if you run it without a cap you will end up needing a new esc. |
04-14-2011, 05:36 PM | #9 |
So does the cap have to touch the wires or can it just touch the posts
04-14-2011, 06:11 PM | #10 |
Rock Stacker Join Date: Nov 2010 Location: Jasper
| Soldier it to the post but make sure you attach it the right way , Positive on the cap to positive post and the negative side of the cap ( the side with the colored half circle ) to the neg side where the battery wires connect to the esc .
04-14-2011, 06:13 PM | #11 |
Quarry Creeper Join Date: May 2010 Location: albuquerque
the top of the posts on the fxr there is a groove, put the cap wires into the grooves (there is a pos and neg side of the cap), heat the solder until the cap wires go into the grooves on the posts, put your wires back on |
04-14-2011, 06:16 PM | #12 |
sorry r34sklnnsn, i was replying at the same time you were, you just beat me |
04-14-2011, 11:08 PM | #13 |
alright thanks guys for the help this is my first time ever using a brushed motor
