Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: what size motor???
Old 04-17-2011, 09:38 PM   #1
riz
Default what size motor???
What size motor would give me more wheel speed than my 55T motor? I'm thinking of converting one of my crawlers to more of a hill climber where more speed / wheel speed would be needed. Thanks in advance.
RIZ
riz is offline   Reply With Quote
Old 04-17-2011, 09:44 PM   #2
More voltage, like a 3 cell lipo. OR a 35t motor. Or both.
SDheavymetal is offline   Reply With Quote
Old 04-17-2011, 09:55 PM   #3
riz
Ok, I was using a 7.4 volt 1000 mAh 2 cell today, tomorrow i will try a 11.1 volt 2200 mAh 3 cell with the same 55t motor. Thanks.
RIZ
Old 04-17-2011, 10:40 PM   #4
Suck it up!
Duuuuuuuude's Avatar
If you want a hill climber, I'd probably go all the way up to a 27t motor, or maybe even a brushless system if you aren't worried about low speed crawling. More voltage is also nearly always a good thing.
Duuuuuuuude is offline   Reply With Quote
Old 04-18-2011, 12:43 AM   #5
if its a hill climber id get a 17.5 or 13.5 b/l setup or there always more volts
crawlinisfun is offline   Reply With Quote
Old 04-18-2011, 08:21 AM   #6
riz
I'm running just the stock Axial 55t brushless motor. I'll see how it goes today with the 11.1 volt 2200 mAh 3 cell lipo vs the 7.4 volt 1000 mAh 2 cell I used yesterday. I'm goingto shoot a few little video clips from my digital camera too and show you all what I was doing.
RIZ
